Softlimit reached dialog disable
Postby johu » Tue Feb 02, 2021 4:40 pm
Hi there,
When I jog the machine, either using the keyboard or the wireless pendant I get a dialog:
"A machine axis position software limit was reached. The axis was now stopped."
This is annoying because the jogging by keyboad can only continue after the dialog is dismissed.
Is there a setting where I can disable this dialog?
johu
Re: Softlimit reached dialog disable
Postby dezsoe » Tue Feb 02, 2021 5:12 pm
You can turn off soft limits on the general settings page, but if it's on then the message will appear.
Postby johu » Tue Feb 02, 2021 6:42 pm
dezsoe wrote:You can turn off soft limits on the general settings page, but if it's on then the message will appear.
Yes, I realize that I can disable the soft limits. But than I miss functionality.
My point is that when soft limits are enabled it's not possible to JOG the machine up to the soft limits and continue normally, you always have to dismiss the dialog. This prevents normal continuation.
What I would like to see is that UCNC get's a feature where the dialog can be disabled.
From my point of view it would be fine to get a line in the "Statusmessage". Alternatively a sound notification would be enough.
johu
Postby Soler » Tue Feb 02, 2021 7:27 pm
Good call, a status message and a sound would be ideal.
Soler
Postby eabrust » Tue Feb 02, 2021 10:59 pm
You can disable the message box for soft limits, there's a checkbox on the 'appearance' tab.
You won't get a beep or a status message, the axis will just gracefully stop, and you can jog away from the soft limit without having to close the message box if you disable the checkbox.
Postby dezsoe » Wed Feb 03, 2021 11:12 am
I didn't remember that... :oops:
Postby johu » Wed Feb 03, 2021 9:11 pm
eabrust wrote:You can disable the message box for soft limits, there's a checkbox on the 'appearance' tab.
This is exactly what I was looking for! Thank you.
johu
Users browsing this forum: Google [Bot] and 29 guests
