1.2112 screenset
Re: 1.2112 screenset
Postby NikolayUA24 » Wed Oct 16, 2019 8:54 am
ger21 wrote:There's a checkbox on the Appearance tab.
I am translating the documentation for the UCCNC into the language I understand. And he hasn’t reached that place yet. Thanks to your hint, I found this chickbox. Thank you very much.
I use Google Translator.
NikolayUA24
Postby NikolayUA24 » Thu Oct 17, 2019 7:06 am
Good day to all.
Tell me what the DTG column displays in the new screenset.
NikolayUA24
Postby cncdrive » Thu Oct 17, 2019 7:11 am
DTG = Distance to go
Postby cpu224 » Sat Nov 02, 2019 9:56 pm
Hi
I have installed and started version 1.2112 today. What should I say, I am excited. The idea to scroll only the upper part of the screen and always keep all the functions at the bottom, I think great. I immediately tested the probing functions and everything worked immediately. Great, keep it up.
Greeting Torsten
Translated by google
cpu224
Postby cpu224 » Sat Nov 02, 2019 10:01 pm
Hi
I forgot something else, my mobile button is 62.17mm high, but I can only set to 50mm. Where can I change that.
Greeting Torsten
cpu224
Postby rfsx15 » Mon Dec 09, 2019 11:12 pm
I have down loaded the most recent UCCNC.zip posting on this forum. I am unable to successfully load 1.2112 onto Win10 or Win7 machines. When installing UCCNC app as 'administrator' I receive an error stating UCCNC has stopped working...it does not load at all. I have been using UCCNC with the 2017 screen set, and would like to look over the beta 1.2112 release. Thanx.
rfsx15
Postby Breizhmaker » Sun Dec 22, 2019 3:21 pm
I'm a new user from UCCNC after years on Ninos a french software ( very powerfull but no more maintained..)
I chose UCCNC which seems to give quite the same features on machine and Gcode management
testing the new screenset and 1.2112 version
first a question: i see on this topic that some zip files are sent to test. Is the version downloadable on http://www.cncdrive.com/UCCNC/setup_1.2112.exe include all theses modification when they are validated ?
As an great user of web cam zeroing, just two observation:
- The camera X and Y offset are not memorized when you shut the software. as fixed data, it would be convenient not to have to enter them at each use.
- A zoom function would be very convenient: depending of your cam, a great zooming help to get an accurate zeroing. i must came back to the old pluging, because i can resized full screen to get higher accuracy.
Best regards
Breizhmaker
1.2112 screenset. Where to set Z probe plate thickness?
Postby PillyWilly » Thu Dec 26, 2019 5:54 pm
Hi
I just installed the 1.2112 version, love the new screenset.
I have looked for where to type in the thickness of my Z probe.
I have been using the 2017 screenset until now, and I do not find the same Z probe screen in this new one.
Regards
Jan
PillyWilly
Re: 1.2112 screenset. Where to set Z probe plate thickness?
Postby PillyWilly » Sat Dec 28, 2019 12:49 pm
PillyWilly wrote:Hi
Regards
Jan
Found another way to do the probing, used the M31 provided by Peter Pasuello, works like a charm :-)
PillyWilly
Postby ger21 » Sun Dec 29, 2019 11:03 am
The 2017 Screenset **should** work OK with 1.2112. You just won't have access to the newer features.
I haven't tried it with a machine, though, so proceed with caution.
