hdbb2 e stop and other connections
Postby Koen Vissers » Tue May 02, 2017 12:28 pm
Hi all,
Excuses for maybe stupid question but Im new user of all these. I tought I was going right but it do not work :oops:
Ok I put the
power suply 35/36 Works ok
Input 1 I used for E stop Contact works on the board but don't work on the software.... (two nc contacts in serial/two e stops) used pin 15 port 1 When pused the led goes out on the board
input 2 used for limit /homing Works on the board but not on the software (5x no npn switch all parallel) used pin 10 port 1 when detected led goes on , on all 5
input 3 used for probe works on the board, cant test because the steppers dont turn. used pin 11 port 1 probe works manualy
First I wanna check off the connections are ok.
All connected with teh UC400eth works ok get connection
Hope someone could drive me in the good direction.
thx Koen (Belgium)
Koen Vissers
Re: hdbb2 e stop and other connections
Postby Koen Vissers » Tue May 02, 2017 6:34 pm
I think I found the problem :oops: :oops: :oops:
If you select port 1 and the cable is in port 2 then it won't work.
Stupid stupid stupid. :? :? :?
Thx for looking
Koen
Koen Vissers
