UC300ETH
Posted: Fri Apr 28, 2017 10:11 pm
Some advice from the collective please
I have at present a uc100 but about to start building a new system as the axis are being a bit glitchy which may be due to a failing bob which to replace would be about £200
new system plan
I have a UC300 ETH am i right in thinking this will drive my inverter with the analog 0-10 out put or have i got that wrong
I dont need to got through a bob if my axis drives have built in optos
and i can just interface I/O though opto couplers normal speed but if i want spindle or servo feed back I would need to use high speed optos (spindle only capable of 3500 converted turret mill Kondia FV1)
if i need high speed what chip would be recommended I would like to try ridged tapping in future
chinese opto 4 inputs/outputs are about £1 each opto isolated relays about £2.5 the idea is to use easy swappable boards at low cost
although my current board does coolant spindle control direction etc when it goes wrong its a pain. it has a custom pic which comes from the states and sometimes its not easy to trace the glitches
Thanks Andrew
new system plan
Thanks Andrew
