Axbb-e wiring
Axbb-e wiring
Postby lexering1988 » Mon Nov 04, 2024 7:28 am
Buongiorno, ho appena acquistato una scheda axbb-e, la dovrei collegare al mio tornio cnc a 2 assi.
Mi servirebbe aiuto nei cablaggi un pò per tutto, partendo dal vfd ho un vevor 1.5kw 220v con GND unico allego foto ed ho un relè ssr per m3-m4 mi aiutate intanto a cablare questo? grazie mille.
relè ssr
Vevor
lexering1988
Re: Axbb-e wiring
Postby lexering1988 » Mon Nov 04, 2024 9:18 am
Good morning, I just bought an axbb-e board, and I need to connect it to my 2-axis CNC lathe. I would need help with the wiring for everything, starting from the VFD; I have a Vevor 1.5kW 220V with a single GND. I'm attaching a photo, and I also have an SSR relay for M3-M4. Can you help me with the wiring for this? Thank you very much.
lexering1988
Re: Axbb-e wiring
Postby cncdrive » Mon Nov 04, 2024 1:30 pm
You have to connect the 24V0 and 5V0 to GND of the VFD.
You have to connect the analog output A01 of the AXBB to the 10V input of the VFD.
You have to connect one isolated output to the FWD (start signal) of the VFD and you have to connect another isolated output to the REV (direction of rotation) of the VFD.
You also have to configure the VFD to get the control from the screw terminals.
And finally you have to configure the spindle setup page of the UCCNC software and you have to attach the Analog output channel 1. to the spindle control in the I/O setup of the UCCNC.
