AXBB-E with Gecko G540 E-Stop Wiring
Postby chaddro » Wed Oct 30, 2024 11:26 pm
Hello,
I bought the AXBB-E to use with my Gecko G540 so I could use ethernet to control the router and your UCCNC software. I am using the DB25 cable to connect directly to the G540 from port 3 on the AXBB-E.
With the G540 you wire your e-stop switch from port 10 of the Geckto through your e-stop and then to the negative rail of the power supply. I am using a 48v power supply to power the G540 and motors.
However, I don't know how I should wire the AXBB-E to recognize the E-Stop when Active. I tried setting the UCCNC software to use port 3 pin 10, but it does not recognized the E-Stop.
Can someone please help me with the correct setup?
Thank you!
chaddro
Re: AXBB-E with Gecko G540 E-Stop Wiring
Postby RsX » Thu Oct 31, 2024 10:20 am
Try setting the e-stop input on port 3 pin 15 which is the FAULT pin of the Gecko drive
RsX
Postby chaddro » Thu Oct 31, 2024 4:46 pm
That worked. Thank you!
chaddro
