change BRKC-180 triggering voltage
Postby taganaka75 » Wed Jun 07, 2023 1:34 pm
I've bought a BRKC-180; I need to change the triggering voltage.
I've read in another forum that is possible by chenging a resistor:
https://www.cncitalia.net/forum/viewtopic.php?f=88&t=53839&start=75#p549687
Someone can help me?
Thank you
taganaka75
Re: change BRKC-180 triggering voltage
Postby cncdrive » Tue Jun 13, 2023 12:00 pm
Hi, I've attached the resistor values vs the trigger voltage levels chart.
Postby taganaka75 » Thu Jun 15, 2023 7:25 am
Thank you for the chart.
can you show me which resistor need to be replaced on the board?
Thank you.
taganaka75
Postby cncdrive » Fri Jun 16, 2023 11:26 pm
Those are the 2 THT resistors on the board closely next to eachother, all other resistors are SMD if I recall.
Postby taganaka75 » Tue Jun 20, 2023 11:56 am
Many Thanks!
taganaka75
