Over travel lite up on screen but no limit switch activated
Postby dhb9mm@gmail.com » Thu May 04, 2023 12:59 am
I am running uccnc software with uc300eth, C95 board, pup no proximity switches for my limit switches. The machine has been running g great like this for about a yr. This morning the over travel light is on but nothing is even close to a sensor. I can take piece of metal and put in front of each sensor, and the red-light on the sensor will come on, and then go off when I move it away.
Could I have one bad sensor that is causing it to throw all of them? Or has my controler, or my break out board gone bad?
David
dhb9mm@gmail.com
Re: Over travel lite up on screen but no limit switch activa
Postby cncdrive » Sat Jun 03, 2023 10:53 pm
Try to disconnect the sensors from the board and check if the problem still happens?
If nort then it could be a broken sensor or it's wire is broken.
