Ethernet CAT Crossover Cable & UC400ETH
Postby wmgeorge » Mon Jan 30, 2023 12:44 pm
OK I am installing the above controller on a Mach4 existing system that resides on a Intel NUC. I have the driver for the Plug in now installed and Mach4 sees it, yes I have it configured in the Network settings in Windows 10 Pro. It says not connected, I am using a standard CAT5 cable so I have ordered a Cross Over cable. Is the cross over cable Aways needed?
In the past I have used a Warp9 ESS and another UC400 but I can't remember if I did or not??
wmgeorge
Re: Ethernet CAT Crossover Cable & UC400ETH
Postby dezsoe » Mon Jan 30, 2023 1:22 pm
I can't remember the last time I used a cross cable. The PCs and network cards made in the last min. 15 years can all switch to cross mode when needed.
Postby wmgeorge » Mon Jan 30, 2023 11:20 pm
Really? I just got the Crossover cable today from Amazon and the UC400ETH connected right up. My Intel NUC is perhaps 4 years old.
wmgeorge
Postby wmgeorge » Tue Jan 31, 2023 1:06 pm
So no Edit and I wanted to add I found my order for the one I did in 2017 and it was with a old Lenovo laptop and it used a cross over also.
wmgeorge
Postby ger21 » Tue Jan 31, 2023 1:42 pm
wmgeorge wrote:Really? I just got the Crossover cable today from Amazon and the UC400ETH connected right up. My Intel NUC is perhaps 4 years old.
You can still use a crossover cable, but you don't need to. Works with either type of cable.
Postby wmgeorge » Tue Jan 31, 2023 2:00 pm
Ger, It would not connect with a standard cable... it does now.
wmgeorge
Postby dezsoe » Fri Feb 03, 2023 3:08 pm
What is the exact type of your Intel NUC? There are many of them. I checked some for spec, but there was no mention about auto MDI-X, so it can or cannot do it.
Postby wmgeorge » Sun Feb 05, 2023 2:35 pm
I changed nothing on the connection side, same IP setup, installed the crossover cable bingo it connects. What would that tell you? The last UC400ETH I used was in 2017 and it was to an older Lenovo laptop, same thing.
wmgeorge
Postby dezsoe » Mon Feb 20, 2023 9:26 am
I'm happy to read that it solved the problem. It seems like cost saving brings back the old days... I was sure that I'll never have to buy a cross cable again, but as I read you're not the only one.
Users browsing this forum: Google [Bot] and 8 guests
