UB1 Analog Output
Posted: Wed Dec 14, 2022 8:01 pm
Hello guys, I'm really hoping you can help me.
I have an eth300 with ub1 board. So far I'm really happy but can't seem to get my spindle control working correctly.
I have connected a 10v supply to the AH1 from my VFD. I've metered it and can confirm it's 10v.
I've then got GND from the VFD to AL1 on the Ub1.
AO1 is wired into the AI1 on my VFD.
FWD signal wired in correctly and works.
On the software I have PWM pin 1 and Port4 as per the manual.
I've set the Analog channel to 0 and 1 and it makes no difference.
All solder bridges are as default.
My max spindle velocity is set to 24000k
If I send s24000 via the mdi and ramp the slider to 100% I only see 7.5v on the Meter from AO1.
I would of expected this to be close to 10v if I understand this correctly?
Any help would be a huge help.
Many thanks
Paul
Many thanks
Paul
