Some question on my stepper motor
Postby shishenkou » Wed Nov 23, 2022 7:51 am
First post and wish i had found this forum a few months ago
They say stepper motor suppliers love newbies
I have a Warco wm18 mill and have added a power z axis stepper but it stalls at high speed
This is the driver i am using - https://www.oyostepper.com/goods-111-Di ... Motor.html
This is the stepper motor - https://www.oyostepper.com/goods-493-Ne ... uder-.html
This is the power supply - https://www.oyostepper.com/goods-914-Me ... upply.html
I have set the driver to 4.2a and i think, can't remember without opening enclosure, to 1600 steps/rev
It works quite well but tends to stall at max speed especially raising the head. For info the head does have a gas strut helper
so where have i gone wrong?
shishenkou
Re: Some question on my stepper motor
Postby Dazp1976 » Wed Nov 23, 2022 10:38 pm
Most people use at least a nema24 566oz stepper with a 48v power supply. You also need a stepper with less than 3mh inductance.
The stepper and psu are too small afaic.
I made the mistake of getting a 1100oz!. I've managed to compensate that by using a DM860T driver and 80vdc power. I can now hit 3700mm/min. It used to stall at 2000.
Dazp1976
Postby Dazp1976 » Mon Nov 28, 2022 12:28 am
Power supply. https://m.aliexpress.com/item/4000232197793.html?
80vdc, 800w.
Stepper driver.
https://www.omc-stepperonline.com/digit ... tor-dm860t
https://m.aliexpress.com/item/32861774473.html?
Stepper motor.
https://www.omc-stepperonline.com/p-ser ... hp29-6004s
With this stepper and driver running together on 80vdc your Z axis should fly!!!!.
Then you can update your x, y, with more of the same drivers connected to your 80v psu, and use these steppers:
https://www.omc-stepperonline.com/p-ser ... hp39-5004s
Nema23/24 motors will have no trouble on these drives at that voltage.
My PM25 mill uses the same.
Dazp1976
Postby Dazp1976 » Mon Nov 28, 2022 12:30 am
shishenkou wrote:First post and wish i had found this forum a few months ago
I've posted some links for a decent, driver, stepper, psu, setup for you to look at.
Dazp1976
