IHSV57 AXBB
IHSV57 AXBB
Postby bearr » Tue Nov 08, 2022 9:42 pm
I have recently ordered a bulkman3D UltimateBee Kit with UC300 and IHSV57 Servos. I also purchased an AXBB-E controller due to some of the bad reviews about the UC300. I have wired up everything and the servo has a green blinking light it will not move at all. I have wired the servo just like I would a stepper and the only thing I get is green blinking light.
I decided to remove all other wiring and motors and connected only one servo and still can not get anywhere. I got PUL+ wired to O9 and Dir+ wired to O10, the axis is enabled. Negative wire for each is going to -5v. I also tried wiring the ENA+ to O11 and set that in UCCNC and it made no difference.
Any help would be greatly appreciated.
bearr
Re: IHSV57 AXBB
Postby fsli » Thu Nov 10, 2022 12:32 am
bearr wrote:I got PUL+ wired to O9 and Dir+ wired to O10, the axis is enabled. Negative wire for each is going to -5v.
You have that backwards. On the AXBB, the output ports are the ground side. You need to connect O9 to Pul- and O10 to Dir-, and connect +5v to the Pul+ and Dir+ terminals. You can leave Ena+ and Ena- disconnected.
Frank
fsli
Re: IHSV57 AXBB
Postby dezsoe » Thu Nov 10, 2022 6:34 am
No, Frank, that's not true. Only the O1 to O8 are open collector outputs, the O9 to O17 are pulled up or down, so you can use both 5V0 and 5V+ as common.
The IHSV57 manual does not mention that the power LED is flashing, but I checked some videos and it seems to be normal.
(In the last few days it's the second time I see "that" UC300. It's a nice job, they even used the CNCdrive logo in their manual. Not perfect on all pages, but they tried to do their best.)
Re: IHSV57 AXBB
Postby fsli » Thu Nov 10, 2022 11:59 am
dezsoe wrote:No, Frank, that's not true. Only the O1 to O8 are open collector outputs, the O9 to O17 are pulled up or down, so you can use both 5V0 and 5V+ as common.
Okay, my mistake.
Frank
fsli
Re: IHSV57 AXBB
Postby ger21 » Thu Nov 10, 2022 1:09 pm
This is not CNC Drive's UC300ETH, which is excellent, but a chinese controller with the same name. FYI.
Re: IHSV57 AXBB
Postby Dazp1976 » Thu Nov 10, 2022 11:36 pm
Ahh. That Novosun, Digital Dream, black box thing.
Makes sense now.
Dazp1976
Re: IHSV57 AXBB
Postby grievousangel » Sun Sep 29, 2024 6:20 pm
I too am getting a Green LED flashing? What does that indicate? Power On but Not Enabled?
Who is supplying +3.5VDC to +24VDC ENABLE signal? I am only measuring 1.5VDC (feeding 24VDC through current limit R2K7 to motor ENA. Why so low?
Thanks, Billy
grievousangel
