UC400ETH + UCSB + HY VFD
Postby arcticus » Sat Jul 23, 2022 12:54 pm
Hi all!
I was wondering if I can get some help connecting my actual setup. I used to have a RnR USB control board and recently bought a UC400ETH + UCSB combo but having some problems to connect it correcly to my HY VFD.
Here is what I have currently connected:
24V 10A PSU
Positive:
    UC400ETH +
    UCSB +
    VFD VI
Common:
    UC400ETH -
    UCSB -
    VFD ACM
I've read on another post that I should connect Output 14 on UCSB to VR(+10V) on my VFD, but I don't have any VR(+10V) on mine... have only a 10V but I think that outputs 10V, wich wouldn't be wise to connect to a UCSB Output (or so I think).
Any help would be greatly appreciated, better yet if anyone uses this setup and can provide the wiring diagram.
Thanks in advance all!
arcticus
Re: UC400ETH + UCSB + HY VFD
Postby ger21 » Sat Jul 23, 2022 11:04 pm
Are you trying to control the RPM with an analog 0-10V? Because you can't with what you have.
Postby Dazp1976 » Sun Jul 24, 2022 9:25 am
arcticus wrote:Hi all!
24V 10A PSU
Positive:
    UC400ETH +
    UCSB +
    VFD VI
Common:
    UC400ETH -
    UCSB -
    VFD ACM
Please tell me you have NOT tried this yet/!!!.
DON'T.
You cannot do this with what you've got.
What you need is to buy a PWM to Analog 0-10V converter board.
You connect PWM side to Ucsb.
Then connect 0-10v side to the hy.
Dazp1976
Postby Dazp1976 » Sun Jul 24, 2022 10:20 am
To add to my previous post.
Look for the board in my previous post image, it is available o Amazon.
It is 24v compatible via junper so you can use your existing 24v power supply.
PWM+ > 24V+
PWM- > UCSB output#
Analog AO > VI
Analog GND > ACM
Set spindle step to UCSB output# you've wired to PWM.
Enable spindle PWM. This should now run through the step output#, to the converter, then across to the 0-10v, then out to the hy VI.
(Do not assign an analog number to PWM) .
You still have 2nd port left empty for additional items by using this simple module.
There is another alternative too.
A cheap 5 axis DB25 board (connected via DB25-IDC26 cable to UC400eth on 2nd port if not using it).
This has a converter built into it on pin#1 that needs 24v to use it and the boards inputs.
This also gives you extra outputs for relays etc BUT: Outputs require 5v and can run 5v only such as 5v relays etc. You can get 5v from pc USB.
This exact one:
Dazp1976
Postby ger21 » Sun Jul 24, 2022 1:49 pm
Another alternative is to use Dan's HY plugin, and an $8 RS-485>USB adapter.
Postby George M » Sun Jul 24, 2022 3:16 pm
ger21 wrote:Another alternative is to use Dan's HY plugin, and an $8 RS-485>USB adapter.
I second this..... Simple and works great.
Thank you
George M
DIY CNC Machine
UCCNC
UC300eth-LPT5
UCBB
George M
Postby arcticus » Sun Jul 24, 2022 5:45 pm
Thanks for your replies. @Dazp1976 I have one of those exact boards (the 2nd one you mentioned and posted pic) on my pile of cnc stuff, in fact that was the first controller I ever bought. Never used it as I moved immediately to the RnR USB wich I used for about a year or so until now the actual UC400ETH.
So far I only have the servos working properly and was going for the Spindle connection. I'm glad I waited for your reply before I did anything :)
@ger21 and @George M thanks for your reply too :)
arcticus
