UC300ETH & UCCNC v1. 2113. Input #15 shown as output????
Postby Dazp1976 » Wed Mar 16, 2022 1:27 pm
As it states.
I've switched pc, set up all the network stuff, all the plugins, license file transferred and working.
So I updated to 1.2113 while I was at it.
Found that input pin#15 in diagnostics page is lit up red on all input ports 1,4 & 5 and shown as O15 (output).
This means 2 of my existing sensors no longer work and I either:
1, Move them to port #5 (which screws up a future plan).
2, Go back to previous version UCCNC.
Has something changed I don't know about?.
Or is this a mistake made by the software creator that will be fixed?.
Dazp1976
Re: UC300ETH & UCCNC v1. 2113. Input #15 shown as output????
Postby ger21 » Wed Mar 16, 2022 3:53 pm
Looks like an interface error. They should still function as inputs, they are just labeled wrong with the wrong color.
Postby Dazp1976 » Thu Mar 24, 2022 6:27 pm
ger21 wrote:Looks like an interface error. They should still function as inputs, they are just labeled wrong with the wrong color.
Looks like you are correct.
It's just an error in the UI.
Works as it should when set as limit switch. Connected prox switch to an isolator module and plugged it in to I15 & GND on port#4. On/off triggered limit/reset.
Dazp1976
