Probe causing circuit breaker
Postby Jason1970 » Mon Mar 07, 2022 3:19 pm
Good day all,
Wonder if someone can please help me . I have and been using a Chinese’s 3040CNC, I connected the probe ( one cable for the Copper board, the other attached to the probe ) all been working fine .
All of a sudden it’s now causing the home circuit breaker to trip , soon as the probe touches the copper plate it’s blowing out and I am not sure why .
Very much appreciate some info what I could try out please .
I thank you
Jason
Jason1970
Re: Probe causing circuit breaker
Postby ger21 » Tue Mar 08, 2022 11:55 am
Sounds like you have a very dangerous short somewhere, perhaps in the spindle?
Postby A_Camera » Tue Mar 08, 2022 3:13 pm
You have a serious earth problem. You should check your wiring. Don't use your machine until you have sorted this out, it may be a lethal problem. No, I am not joking, I am dead serious.
Postby Jason1970 » Tue Mar 08, 2022 3:45 pm
Ok I will get someone to check this .
It had been working perfectly since then :(
Thank you for your replies .
Jason1970
Postby Jason1970 » Wed Mar 09, 2022 11:28 pm
Hello . Quick question, should there be any voltage between the probe and the copper plate ( when I have the copper plate grounded )
I am getting ~5v
Thank you
Jason1970
