UCCNC 300ETH and SKI780 Inverter
Postby kucharzb » Fri Nov 19, 2021 10:34 pm
Hello everybody,
newbie to the UCCNC Forum here :)
I just replaced the cheap china motion controller with 300ETH Model (with Breakout board, big model), so for so good / been able to turn on relays and servos. But I am a bit confused with Inverter connection. I was searching on the forum, but I didnt find defintiv answer...
Can someone take a look at my inverter and tell me, what would be the best option to control my spindle?
Here is the manual:
https://www.google.com/url?sa=t&rct=j&q ... n-AyrgzozA
Is the 10V control over the analog IDC16 connector the only option? or can I somehow use the Breakout Boards for that purpose? Or 10V control is not that great and I should consider RS485 / if so - will the Ethernet to RS485 work with UCCNC software?
Thank you for supporting!
Kris
kucharzb
Re: UCCNC 300ETH and SKI780 Inverter
Postby kucharzb » Sat Nov 20, 2021 10:54 am
I do not see the option to edit the post :(
I thought of two possibilities:
PIN D5 (digital input in the inverter) - but here somebody would need to confirm if it is possible to control it directly from the 300ETH board
OR
RS485 - Ive seen those dodgy USB to RS485 converters - I would love it use Ethernet instead due to different reasons - is somebody using this solution (LAN to RS485) - does it work properly? DO I need special plugin for that or the one for USB works as well? Some ideas?
kucharzb
Postby cncdrive » Sun Nov 21, 2021 11:34 pm
Yes, using the 0-10V analog output of the UC300ETH-5LPT should work fine.
You could also use RS485 through USB or ethernet with a suitable adapter.
Both solutions should work, but in my opinion the simplest is the analog 0-10V signal as the UC300ETH already has that and then there is no need for extra hardware.
Postby kucharzb » Sun Dec 05, 2021 9:04 am
I decided to go for RS485/Modbus - and slowly got it running / at the moment with PC Modbus as Master, but I will try to configure the macro, so that it is all well integrated.
kucharzb
Postby tuxmicro » Thu Jul 07, 2022 9:38 pm
Hi, can you share your preview of the commands you used for communication via Modbus (RS485)?
Thanks a lot
tuxmicro
