Advice-new spindle motor drive
Posted: Mon Jul 05, 2021 4:49 pm
Greetings-
I am looking for advice on upgrading the spindle motor drive on my old mid-80's vintage mill. OEM design uses a brushed DC motor (see nameplate below) driven by a Servo Dynamics servo driver. Reasons for upgrading: both the driver and the tachometer mounted on the motor are damaged, and rather than trying to fix everything I'd prefer to modernize and just dump the old stuff. I have components for repairing the driver but the tachometer is needed for the driver and that could be more problematic for repairing. Also the driver takes up a huge amount of space in the cabinet. The motor is in good condition--I just replaced the bearings and it runs very well, so I'd prefer to keep it. Advantages to keeping the motor are mounting hardware would not need to be retrofitted, the motor includes a built in brake which I like having, and if I remove the tachometer there is a ready made space for an encoder, if needed.
I have been looking at CNCDrive's DG4S-16035 as a replacement but have questions:
1. Is this a good way to go or is there a better alternative to driving the motor, using UCCNC for program control? I know next to nothing about servo drives and just wonder whether this is overkill for driving the motor or is this a preferred method? What would be involved in configuring--is it fairly straightforward to set up for a spindle motor?
2. Recommended PSU?
3. Looking through the manual for the DG4S-16035 it appears that it needs an encoder for operation, what encoder is recommended?
4. Not sure I would need a braking board since the motor has a built in brake and stops the motor fast enough to prevent excess back voltage, but on the occasion that the motor speed needs to drop in the middle of a program it could be a problem. Since a braking board is relatively cheap in the scheme of things I would probably include it anyway.
Trying to keep this brief initially but if more info is needed let me know.
2. Recommended PSU?
