Suitable Laptop PC
Suitable Laptop PC
Postby Spuds » Fri Apr 16, 2021 1:37 pm
Hi folks. I just built a small 3 axis machine and now need a PC.
Can you tell me if this little guy would be suitable ?
Brand new, never online, for UCCNC and AXBB_E, maybe CAD/CAM ONLY ! maybe for several machine profiles.
https://www.officedepot.com/a/products/ ... aptop-116/
Thanks, just want to be certain before I buy.
Russ
Spuds
Re: Suitable Laptop PC
Postby cncdrive » Fri Apr 16, 2021 4:36 pm
The link says that the website is currently not available, so I could not check it.
Postby Robertspark » Fri Apr 16, 2021 9:15 pm
PDF attached
HP Stream 11 ak0010nr Laptop 16V14UAABA - Office Depot.pdf
(580.33 KiB) Downloaded 505 times
Postby Robertspark » Fri Apr 16, 2021 9:17 pm
no ethernet?
Postby Spuds » Fri Apr 16, 2021 11:06 pm
Robertspark wrote:no ethernet?
I have a USB 2.0 to Ethernet adapter that I hoped would work OK. I read here somewhere that it would work fine.
Confirm ?
Spuds
Postby Spuds » Mon Apr 19, 2021 12:00 pm
cncdrive wrote:The link says that the website is currently not available, so I could not check it.
Hi Cncdrive, were you able to check the info ? Would you expect it will work with the aforementioned adapter ? If so, I want to order one today.
Thanks for your assistance,
8-)
Spuds
Postby cncdrive » Mon Apr 19, 2021 10:09 pm
No, the website still says it is offline.
Postby ger21 » Mon Apr 19, 2021 10:23 pm
Must be due to your location.
Robert uploaded the specs above.
Postby cncdrive » Tue Apr 20, 2021 12:58 am
I have checked and the processor frequency 1.1 GHz looks a little low, but it is dual core, so it should be OK.
Postby Spuds » Wed Apr 21, 2021 9:45 pm
Thank you folks.
I just got this one. Used, but looks to be in good working order.
Intel Celeron N2840 2.16 GHz
Installed RAM 2.00 GB (1.9 usable)
Windows 10 Pro 64 Bit
Anxious to get it loaded and hooked up !
Thanks again,
Spuds
