I've been running my CNC with Mach3 for a while (with a direct parallell port connection to my BOB) but now I have bought a UC300ETH and also UCCNC. The problem is that I can't get it working, neither in UCCNC or in Mach3 with the plugin.
Inputs work but I cannot move the CNC. When I switch back to my old setup everything works fins so the BOB seems ok. So I suppose there might be some kind of simple mistake I've made.
I've tested bot LPT1 and LPT2 on the UC300ETH but with no difference - inputs work but not outputs, I've started thinking of if it's my BOB that don't work with the UC, I've attached a image of it below. I'm having a "straight" IDC -> DSUB25 cable between them.
Anyone having an idea what I've might down wrong?
Thanks for any ideas!
