UC400ETH for breakout board
PostPosted: Thu Sep 10, 2020 5:25 pm
by andyjack38
Hello, is it possible to use a C25 breakout board with the UC400ETH and have more than 10 inputs
Re: UC400ETH for breakout board
PostPosted: Thu Sep 10, 2020 5:37 pm
by Robertspark
No,
The UC400ETH has 2x STANDARD (pins 2-9 as outputs only) 26 pin IDC connectors.
if your want lots of IO's get s uc300eth, its not much more in cost.
PostPosted: Thu Sep 10, 2020 6:12 pm
by andyjack38
ok Robert, but i have UC400ETH and what about this C25 breakout board can I use it
PostPosted: Thu Sep 10, 2020 6:38 pm
by Robertspark
https://www.cnc4pc.com/pub/media/produc ... er.3.2.pdf
I would say No.
You can only use 1 port on the C25 as the 2nd port has pins 2-9 set as INPUTS, this is not possible with the uc400eth.
The smooth stepper allows you via firmware to change the use of pins 2-9 to either be outputs or inputs. This is not possible.
Your could get 2x el-cheapo Chinese BOB's
https://www.omc-stepperonline.com/image ... 0x1000.JPG
Or 2 x C10
https://www.cnc4pc.com/c10-bi-direction ... -card.html
Or 2 x UCCNC offerings
http://www.cncdrive.com/UCSB.html // https://www.cnc4pc.com/ucsb-single-port ... board.html
http://www.cncdrive.com/HDBB2.html // https://www.cnc4pc.com/high-definition- ... -hdbb.html
