wire alarm to axbb-e
Postby Alexi » Tue Sep 08, 2020 10:46 pm
Hello to all members,
Sorry for my bad English.
I´d like to know how can i connect the alarm signal of my leadshine AM882 to my controller AXbb-E ?
All other connections are similar to axbb-E manual.
If i wire for example Alarm+ to pin 12 and alarm- to ground will it work or will it typical make smoke signal?
I try to check for continuity on circuit and force error but circuit remains open for both conditions in normal run and in error with red led blinking.
Is this just o "normal" NC or NO contact? Manual of drivers is not that clear.
Thanks in advance for help
Alex
Alexi
Re: wire alarm to axbb-e
Postby dezsoe » Wed Sep 09, 2020 8:51 am
Hello Alex,
Connect 24V+ to I2+, I2- to Alarm+ and Alarm- to 24V0.
Postby Alexi » Wed Sep 09, 2020 1:05 pm
Hello,
Thanks for help.
This means that it will act as a regular switch no/nc type?
Should I have any continuity when drive gives an error?
Alexi
Postby dezsoe » Wed Sep 09, 2020 3:49 pm
Yes and yes. But it will conduct only in one direction, because it's like a diode. (Search for open collector NPN.)
Postby Alexi » Wed Sep 09, 2020 5:16 pm
Thanks mate. I will search more for collector NPN.
Alexi
Postby Alexi » Wed Sep 16, 2020 3:53 pm
Hi
Can you tell me what config should i put on mach3 for this wiring?
I can only choose from pin10-13 and 15.
Alex
Alexi
Postby Alexi » Wed Sep 16, 2020 4:13 pm
Solved port2.
Alexi
