I am trying to re-purpose a router gantry frame from AVID CNC for a dedicated 4axis hole drilling and tapping station. I plan to drive a R8 spindle with an AC servo motor connected with a toothed XL belt at a 2:1 ratio. I am at a bit of a loss as to how to wire this together and the electronics I need. My other router setup uses a UC100 and I am guessing that the 5 input pins are maxed out with
1. Probe
2. XYZ home/limits
3. Y2 home for squaring
4. blank
5. blank
As I understand it, UCCNC needs three input signals for the spindle encoder? Is there a way to supplement the inputs of the UC100? If not which controller would be recommended. Also many of the threads I have read through use an external encoder than the one built into the servo or servo amplifier. Is this something that is really required? Any guidance or reference links for this sort of thing would be greatly appreciated.
Thanks.
