I'm currently bringing back to life a non-functional Suregrave engraver by installing an AXBB-E, new drivers and pwm controller for the brushed spindle motor. So far I've got my head round most of the potential problems but as I haven't yet received my controller (should be delivered tomorrow) I'm still very much in the planning phase. No doubt I'll have other questions but here's the first one I haven't managed to find an answer to yet.
The original engraver is fitted with a good quality power supply, big toroidal transformer, rectification, smoothing, and regulating pcb and as I also want to use the original case I'd like to use this supply. The psu produces 5.0V, 36V (for the steppers) and what I had originally assumed would be 24V for the spindle, as that's what it is rated at. My thinking was that I could also use the 24V to supply the AXBB but I've measured the actual voltage and it's 25.3V. The AXBB manual specifies 12V to 24V, is the 25.3V likely to be too high? It's not a serious problem, I've also got a separate 24V supply but that means adding another box inside the case and it may get crowded in there, which I'd rather avoid.
Anyone able to offer any advice?
