I connect the alalog output of HDBB board to the spindle controller and had a strange responce so i decide to connet also the ground of the ouput to the ground of the controller. this causing a short circuit?!!? and i disconnect it. From that time, no led inducation on the drivers?! i check the 12volts provided by HDBB and was ok.
The ethernet controler and HBDD looks fine except the drivers.. i remove one of them and provide 12 volts from another resource but nothing hapened.. i also try to feed it by 5 volts on pin 4 without result.. i notice that on 5V should be a short circuit because i restrict the ouput current of my power supply to 0.5amps before power it up and shortage indicated.
Any advice? how this can be happened?
