PRG01 USB Programming Stick
Postby emanuel » Fri Mar 06, 2020 2:19 pm
I am trying to put together a system with HDBB2 and 3 DG2S-08020 drives.
While using the Servoconfigurator3 I a strange thing is happening:
No matter to which drive I am connecting the USB stick, it always shows the serial number of one of them (Z in my setup)
The PID data is different, the drive connected reacts to tests from the software.
I can't understand what is wrong.
emanuel
Re: PRG01 USB Programming Stick
Postby emanuel » Sun Mar 08, 2020 9:15 pm
I have this problem with one of the drives.
My setup has 3 identical motors all connected to DG2S drivers.
All with the same servoconfigurator setup as in screenshot 1
2 of them somehow respond and move, and I get on the analisator a pulse as shown in screenshot 2
But the third motor will move all the way until hits the stop and will show like in screenshot 3
3 - Z motor
2 - X & Y motors
1 - Settings
emanuel
Postby cncdrive » Mon Mar 09, 2020 2:08 pm
It is always the programming stick serial number is what is shown in the Servoconfig software.
The assignment only worked with our older drives which had built in USB chip.
The encoder on the motor is not counting if it runs away infinately.
Postby emanuel » Tue Mar 10, 2020 6:29 pm
cncdrive wrote:It is always the programming stick serial number is what is shown in the Servoconfig software.
The serial number I get belongs to one of the drives
emanuel
