Does the MPG Handwheel need to be 24VDC or can other voltage Handwheels be connected? The diagram in the AXBB-E is pictured with the MPG connecting to 24V.
I have a 5V hand wheel. Can someone please confirm if I can connect the MPG to a 5V supply voltage? Connect the MPG VCC ( +5VDC ) terminal to the two AXBB-E isolated input positive terminals and the MPG A/B Wires to the respective Isolated Inputs negative terminals, would this work?
Really what I am asking is can I use a 5V DC supply on some of the isolated inputs and instead of the 24V DC pictured and still use 24V for other Isolated Inputs (i.e. NPN connections)?
https://www.dropbox.com/s/pq6a8rh8xis3oyk/Isolated%20Inputs%20Question.png?dl=0
