C76 Analog Inputs
Posted: Thu Jan 02, 2020 3:44 pm
Anybody using the UC300ETH with the C76 board from CNC4PC and UCCNC software. I'm have questions on analog inputs.
On the analog I/O port on the C76 when I feed pin 1 to one side of the pot (5vdc), pin 2 to the other side of the pot (gnd), and tie the pot wiper to pin 4 (analog input 2) i can see the analog value on the diagnostic scree change but I don't get the full 655335 value because I am only using 5vdc instead of 12vdc.
When I try to tie the wiper of the pot to pin3 (analog input 1) I see no change as if the pin out in the C76 manual is not correct. I even tried pin 11 for analog input 1 with no results.
My questions are how do I get the full range input values of 0-655335 on analog inputs with only 5vdc and why I can't get a reading on analog 1 if the documentation is correct.
Anybody here ever work with the C76 board?
Matt
Matt
