huanyang
huanyang
Postby windows20 » Mon Apr 08, 2019 4:36 pm
is anyone using the hauanyang inverter with the axbb-e.if so can you help me set up please.
windows20
Re: huanyang
Postby cncdrive » Mon Apr 08, 2019 11:15 pm
It should be simple to connect it. Just connect the analog output signal of the AXBB-E to the analog input of the VFD like how it is shown in the AXBB-E manual.
And connect a start signal and optionally a direction signal.
And configure your VFD to read the analog signal for spindle speed reference and to read the start signal from the screw terminals.
These can be set with some parameters of the VFD. The VFD manual describes them...
Re: huanyang
Postby windows20 » Tue Apr 09, 2019 6:48 am
This is my problem I don't understand the manual at all.got the vfd settings all done,just don't understand what the wiring means.
windows20
Re: huanyang
Postby windows20 » Tue Apr 09, 2019 11:18 am
ok if i put forward which is 24v to the 24v input and ground to pin 17 am i going about this the right way.
windows20
Re: huanyang
Postby ger21 » Tue Apr 09, 2019 12:18 pm
FWD and DCM should go to a relay. Have the AXBB toggle the relay with the M3 command.
Re: huanyang
Postby windows20 » Tue Apr 09, 2019 12:35 pm
Surely there must be a way of doing this without a relay
windows20
Re: huanyang
Postby windows20 » Tue Apr 09, 2019 4:17 pm
ok set up the relay so now i can turn it on and off.how do i connect to control the speed now.
windows20
Re: huanyang
Postby ger21 » Wed Apr 10, 2019 12:54 am
It should be AO1 from the AXBB to VI on the HY.
5V on the AXBB to ACM on the HY.
Make sure the J1 jumper on the AXBB is removed for 0-10V.
Re: huanyang
Postby windows20 » Wed Apr 10, 2019 9:26 am
thanks ger21 got it all set up but still cant controll speed from software.do i need to set pins in pwm and if so what numbers should i put in for them.
windows20
Re: huanyang
Postby windows20 » Fri Apr 12, 2019 11:51 am
is there some thing i need to set for the analog output,not getting any voltage from there.
windows20
