This is my first post for a new installation of UC300Eth and Gecko drives into a Gerber Sabre 408 router with an IDM Controls Inc. P5 Series General Purpose AC Drive.
Here is the manual. https://manualzz.com/doc/7291098/p5--inverter-manual
This is my first time building a system like this and have never worked with servo's before.
I need to identify the 3 control wires and connect them to UCCNC. Cannot tell which wire is which to assign ports. Should I connect to a digital or analogue port?
Thank you for your help.
-Chris
Control Method
Sine wave PWM with full-range, automatic torque boost
Frequency Control Range
0.1 to 400 Hz
Frequency Accuracy
Digital command: 0.01%, Analog command: 0.1%
Frequency Setting
Resolution
Digital Operator Reference: 0.1Hz,
Analog Reference: 0.06Hz (@60Hz)
Output Freq Resolution
0.01 Hz
Frequency Setting
0 to +10VDC (20k
Ω
), 4-20mA (250
Ω
Accel/Decel Time
0.0 to 3600.0 sec.
(Accel/Decel time setting independently: 0.1 sec )
Braking Torque
Approx. 20%
No. of V-f Patterns
1 preset V/f pattern and 1 custom pattern
