AXBB-E and VFD control
Re: AXBB-E and VFD control
Postby DavidR8 » Tue Nov 19, 2024 10:10 pm
I tested it and something doesn't make sense.
System energized the voltage between O7 and GND is 15.62V
Start the spindle with M3 S24000, the voltage drops to .001V. O7 indicator light is on but flickering somewhat.
Decrease the speed with the slider the voltage increases:
24000 rpm = 0V
14000 rpm = 6V
12000 rpm = 7.7V
9700 rpm = 9.25V
Shouldn't the voltage stay at 0V?
DavidR8
Postby cncdrive » Wed Nov 20, 2024 3:03 am
The Voltage on the start signal should drop to 0V on the M3 command and stay at 0V until the spindle is stopped.
Postby DavidR8 » Wed Nov 20, 2024 3:07 am
Any idea why it's not?
DavidR8
Postby DavidR8 » Wed Nov 20, 2024 4:56 am
I think this is the solution.
viewtopic.php?f=4&t=4913
DavidR8
Postby DavidR8 » Fri Nov 22, 2024 4:15 am
I wired in a 24v relay using my O1 output as the trigger and the switched side to the fwd and XGND.
DavidR8
