Connecting AXBB with Gecko G201X step drives - charge pump?
Re: Connecting AXBB with Gecko G201X step drives - charge pu
Postby mschoonmaker » Wed Nov 06, 2019 11:26 am
Here is GeckoDrive Tech Support response:
The issue with a DC side switch is inrush current. Opening a switch is not a problem but closing one can cause very large currents for a short period of time. We recommend putting a current limiting thermistor in between the drive and the switch if you cannot avoid using a switch.
mschoonmaker
Postby cncdrive » Wed Nov 06, 2019 11:41 pm
Well, in this case the problem is not the charge pump relay, but what they wrote means that if you powering up the drive using a switch to turn the power to the drives then they can damage. Strange if they think that this is OK. :o
