AXBB hookup question
Postby Greolt » Sat Mar 09, 2019 10:39 pm
Can I hookup my THC in the way shown in pic?
The THC outputs a 24v signal (probably 12v in my case)
Prevously I was using Mach3 via LPT with BoB, I used some opto-couplers to get an on/off switch from that voltage signal.
Now I am installing the AXBB in the plasma CNC.
I think this will be OK but wanted to check. Do I need to add a current limiting resistor?
THC is entirely separate from the AXBB power supplies.
Shown is arcOK signal. It will also have UP and DOWN signals.
They all three share a common return on the THC. Can I daisy chain the negative connections on the AXBB?
Greolt
Re: AXBB hookup question
Postby dezsoe » Sat Mar 09, 2019 10:59 pm
Yes, it's OK. As you can see in the AXBB manual, the inputs are designed for 24V, so you don't need any resistors. The - pins can be common.
Postby Greolt » Sat Mar 09, 2019 11:24 pm
Thank you Dezoe
No doubt I will soon have more questions. :)
Greolt
Postby Greolt » Sun Mar 10, 2019 9:25 pm
Could not find this info in the manual.
What current is the isolated input capable of sinking.
Many similar devices I have used in the past have a 20ma limit.
Assuming this can handle more than that.
Greolt
Postby Robertspark » Sun Mar 10, 2019 9:33 pm
Page 19 and 20 of the axbb manual states the inputs have 2.2k ohm resistors
Ie 24volts/2200 = 10mA approx
Postby Greolt » Sun Mar 10, 2019 10:43 pm
Thanks for the pointer (reminder to RTFM) Rob :)
Port#1 pins 2. to 8. are isolated outputs. These outputs contain high speed 10Mbit/sec optocouplers and an N-channel Mosfet transistors.
The outputs can drive up to 500mAmps of current up to 24Volts voltage levels.
The high current capability of the output transistors makes these outputs ideal to drive relays, solid state relays and other signals which require isolation.
My relay that draws 38ma should be fine.
Greolt
Postby cncdrive » Mon Mar 11, 2019 12:19 am
Yes, there are power mosfet transistors on the outputs. We recommend switching up to 500mA current max. per output. It should be more than enough even for large relays.
Postby Greolt » Fri Apr 05, 2019 12:21 pm
My second AXXB is about to arrive. This one is going in my router.
Most of the hookup is straight forward. Inputs are fine.
However I have five axis to control and only eight non isolated outputs on port 1.
So I am wondering should I control the fifth axis (step and direction) with two isolated outputs on port 1, or pick up two (assume non isolated) outputs on port 3.
These would be connected direct to pins on port 3. I don't have real estate for a BoB just for two extra outputs.
Drives have isolated inputs.
Greolt
Postby dezsoe » Fri Apr 05, 2019 12:25 pm
If the inputs on your motor driver are optoisolated then you can connect them to port 3.
Postby Greolt » Fri Apr 05, 2019 12:27 pm
Thanks Dezoe
So hooking direct to pins on port 3 should not be a problem.
Greolt
