ger21 wrote:This jumper determines whether UCCNC sees it as a 5LPT board or a UB1 board. Different screens are loaded based on which board is detected.
UB1 manual wrote:The UB1 was developed by following UC300ETH_5LPT Motherboard pin out. Choosing the 5LPT jumper will get 100% pin to pin compatible, except analog channel output 2 which will not function properly. Choosing the UB1 jumper the user will get 100% pin to pin compatible and the analog output will function properly. The reason for this is that the UB1 isolated analog circuit uses a frequency of 1 kHz while the 5LPT board uses a frequency of 48 kHz.
Users browsing this forum: Google [Bot] and 6 guests
