Hi All,
I am thinking of buying a AXBB-e controller after hearing a very enthousiastic person on the dutch CNCZone forum.
Only 3 questions remain:
1.
My spindle (watercooled 1,5kW) is driving by step/dir signal (so not a VFD, the driver looks more like a very very big stepper driver, giving 3 phase 230V, 8A).
Can the AXBB-e using the plugin in Mach3 drive my spindle like i now control it with my Smoothstepper *current controller i want to replace by AXBB-e) ?
2.
In the schematic i see all home switches are connected in series.
Does that mean when it is home Z for instance, it just waits until one of the switches is triggered, then backs off (closing the circuit again) and then homes the next axis, and then the last axis ?
Or is it also possible to give every home switch is own input port ?
3.
Can Inductive home sensors be connected without any pullups/pulldowns/transistors etc just like is mentioned in the manual ?
On my current setup (Smoothstepper plus C25 breakout board) there were LEDs mounted on the inputs which caused so much current draw i had to do all kinds of trickery to make my inductive endstops (kinda) work.
In the end, i was so fed up i removed them, although i really liked them, hope it's possible to reinstate these again with the AXBB-e ?
Hope someone can answer these, after that i will buy the controller.
