Uccnc plasma, Sheetcam, floating head. Trouble with height
Postby SM_1 » Sun Mar 03, 2024 9:08 am
Hi, I have converted my Esab Cnc plasma with UCCNC Axbb-e and I use Sheetcam. I will add a scriber later so I use the UCCNC Plasma with scriber PP. I have a Proma THC150 and a Hypertherm powermax 105 using the CPC dividided voltage for the THC. I'm all new to Cnc systems but made the conversation myself.
I did the first live test yesterday, but after the M31 command the plasma height is higher than the settings. Like 5mm higher than the pierce height. So I think I need to change some offset of the floating head switch. Checked the settings in the Plasma scriber PP but it doesn't have any switch offset settings.
I would appreciate all the help I could get. Anyone else here that use a similar setup with this sheetcam PP and UCCNC?
I'd the problem in the PP, job settings in Sheetcam or in the UCCNC software?
SM_1
Re: Uccnc plasma, Sheetcam, floating head. Trouble with heig
Postby SM_1 » Fri Mar 08, 2024 11:50 am
I answer the question myself if somebody have the same issue. I changed the M203 Macro name to M31. Changed the offset in the old M203 macro and now it works well.
I'm looking for a better THC then Proma THC 150 but that seems easier than it is...
SM_1
Postby Megadiycncplasma » Wed Mar 27, 2024 2:38 pm
do you have any screen shots on how and what you changed i am new to uccnc and have the same hardware and issue as you other than i have a 65 instead of a 105
Megadiycncplasma
Postby Megadiycncplasma » Mon Apr 01, 2024 2:56 pm
can you by chance show me were and what you changed i have the same hardware you do and i am having major probing issues. i have no problem cutting as long as i use the sheetcam pp for uccnc with no z and manually set the z. if u use the pp with z it goes down touches go up then instead of probing to the right height it goes all the way up and hits the limit switch.
Megadiycncplasma
Return to CNC Plasma
