Plasma Wiring
Plasma Wiring
Postby Delco » Fri Dec 01, 2023 2:41 am
Hi been looking for a suggested wiring diagram for a UCCNC setup with a proma 150 THC.
I had no luck so checking if I have forgot any outputs/inputs
I believe I need :
Outputs
X Step
X Dir
Y Step
Y Dir
Z Step
Z Dir
Y2Slave Step
Y2Slave Dir
Inputs
THC Up
THC Down
Arc ON
Torch Break/E Stop
XYZ Home switch
Y2 Slave Home Switch
Torch Probe switch
Any inputs Im missing ?
Originally I was going to use a UC300 and a UCSB but it only has 5 inputs so looks like a UCBB or a AXBBe is needed.
Delco
Return to CNC Plasma
