Arc OK not working
Arc OK not working
Postby b57378 » Tue Jul 05, 2022 9:04 am
Hi all hope everyone is doing great.
Would appreciate some insight on a problem I'm having.
My arc OK signal coming from the plasma inverter is working as expected - when torch fires, arc OK signal is on and when torch off, the arc OK signal is off.
For some reason the motion is not stopped if the torch is abruptly turned off? Am I missing something here?
Thank you in advance.
b57378
Re: Arc OK not working
Postby cncdrive » Tue Jul 05, 2022 5:48 pm
There is a checkbox settings for that with which you can make the controller to wait or to not wait for the arc ok signal.
Postby b57378 » Wed Jul 06, 2022 5:58 am
Thank you for the prompt response, I'm assuming that would be in the IO Setup tab but I don't see it? Only the arc OK input settings and Thc functions
b57378
Return to CNC Plasma
