New build using the AXBB-E
Postby Healinhand » Thu Jun 09, 2022 11:47 pm
I need a little help with wiring an AXBB-e input. Im using the Thermal Dynamics Cutmaster 60I.
Healinhand
Re: New build using the AXBB-E
Postby cncdrive » Fri Jun 10, 2022 3:56 am
You need a THC (Torch height) controller to connect this to. And you then connect the THC controller to the computer or to the AXBB-E depending on what kind of THC controller will you be using.
Postby Healinhand » Fri Jun 10, 2022 2:35 pm
I have a Proma 150
Healinhand
Postby cncdrive » Sat Jun 11, 2022 3:25 am
You have to connect it accorting to your THC controllers users manual.
The proma controller can input the arc voltage directly and it can also accept divided arc voltage signal.
The plasma start stop signal you can drive with a relay from your breakout board, that signal is used to ignite the arc voltage, so you can configure that output pin as M3 relay and then you can turn the plasma arc on/off using the M3 macro from code or with the spindle CW button on the UCCNC screen.
I'm not sure about the othe signals.
The OK to move is probably an output which can tell the controller that the plasma unit is powered up and ready to work, so you could connect that to an input of your breakout board and could configure it e.g. in the fault signals plugin.
Postby Healinhand » Sun Jun 12, 2022 3:50 pm
Thanks for the help!!!!! I was hoping someone with the same setup would help with a schematic
Healinhand
Postby Robertspark » Sun Jun 12, 2022 9:13 pm
Postby Healinhand » Mon Jun 13, 2022 1:23 am
Thats awsome!!!! Thanks for the help
Healinhand
Return to CNC Plasma
