1st build plasma cutter. M31 during Gcode run question....
Posted: Thu Jun 09, 2022 1:11 pm
Hi all. Total newbie here. I've built a non THC floating Z plasma cutter and due to previous experience with "other" software I went with a compatible eth controller and the "other" software however I've given up trying to get M31 to work before every cut. From what I can gather the "other" software although good motion control software melts down if macros are run while running Gcode, and they seem to have no intention of rectifying it.
I've purchased an AXBB-E controller and when I have time will swap it in and also start setting up UCCNC on my laptop.
Question: Does UCCNC run M code macros reliably during Gcode ie. Call a z axis touch off "M31" and execute G92 axis dro overwrite reliably prior to each cut or is it buggy like the "other" software?
Thanks.
Thanks.
