Breakout board-Start relay-Interface cable???
Posted: Mon Jun 29, 2020 2:19 am
I’m still retrofitting my plasma table with new UCCNC equipment. Of course I saved the things I understand least for last.
Im trying to connect a UCBB breakout board to my powermax 65 machine interface cable’s “start plasma” wires. I also have this new Salon D-121 relay module that goes between the two. I can’t figure it out. It’s nothing like my old gecko540 and crappy automotive relay in the old setup. I’m over my head. I’ve got the 12v +/- wires connected from the power supply to the VCC/GRD pins on the relay. That’s it. I’m drawing a blank on rest. There is a green wire and black wire from the interface cable that need to connect to the relay but I’m not sure where they go. Also, I need a wire from breakout board output 1 to the relay. I’m confused on that. In my mind there should probably be a second wire from the breakout board connecting to the relay too, but like I said, I’m confused.
Also, with the new software, once it’s wired properly, how do I dry test it without actually firing it up. Can somebody make sense of this hole mess for me?
All the best,
Scott Meer
All the best,
Scott Meer
