Dwell starts before ARC ON / ARC OK
Re: Dwell starts before ARC ON / ARC OK
Postby spumco » Sun Feb 25, 2024 3:18 am
@mechcnc,
I have had the same problem for a couple of years. Primarily on plasma drilling operations with very short pierce delays (G4 P0.4).
As you described - first hole the torch fires, after that the dwell timer starts & expires before the ARC OK signal is triggered. Result is that all subsequent holes are not pierced.
Also have intermittent mis-fires during non-drill operations on very thin material (0.040") where the pierce delay is extremely short.
The wait-macro described in the post you linked hasn't worked for me. However, I did manage to get a different hack working today.
Mentioned in a couple other threads from around 2020 was a suggestion to issue a small movement command after M03 (torch fire) and before the G04 pierce delay. So I added the following after every M03:
M03
G91
G1 Z0.0001 F100
G90
G4 P0.4
And the misfire went away completely. Did ~150 drill pierces in one session today and no misfires.
Edited my sheetcam post processor and now sheetcam outputs every file with the above 'dummy' move and the pierce delay timer doesn't start until ARC OK is on.
So if you need a workaround while cncdrive and dezsoe work on a bugfix, you might try adding the above to a test program and see if it helps.
Sheetcam post edit:
post.Text ("\n M03\n")
post.Text ("\n G91\n")
post.Text ("\n G1 Z0.0001 F100\n")
post.Text ("\n G90\n")
if (pierceDelay > 0.001) then
post.Text (" G04 P")
post.Number (pierceDelay,"0.###")
post.Eol()
end
spumco
Postby mechcnc » Tue May 07, 2024 3:22 pm
Thank you very much Spumco, I will try this. It seems like a great workaround for the time being.
Ive been trying Fusion 360 and ProNest until recently, and just now starting to experiment with the demo version of Sheetcam as well. It gives a lot more freedom of choice for the user compared to for example Pronest (which in the beginning feels bad because the learning curve is steeper, but in the long run its better for me). I will head over to their site and buy a license today.
Have a good day (or evening depending on where you are in the world)!
mechcnc
Postby gerius25 » Sat May 25, 2024 4:36 pm
Any luck solving the problem?
gerius25
Postby mechcnc » Fri Jun 07, 2024 10:32 am
Ive tried the Z-movement command in between the M03 and dwell, but the waiting for arc OK only works sporadically for me. I have a switch in series with the relay that turns on the plasma cutter, so I can override the closing of the circuit which would turn on the plasma cutter. Sometimes when I turn the switch off (no arc will come from plasma cutter) UCCNC will just move forward with the program anyways. Other times, even within the same program, I hear the relay click and it starts to wait for the arc OK signal as intended.
Have you tried anything similar with an override switch, @spumco?
Is there an update on the horizon that will fix this, @cncdrive?
Br
mechcnc
Postby cncdrive » Fri Jun 07, 2024 5:54 pm
Yes, we will release 1.2117 soon, it will fix it.
Postby mechcnc » Wed Jun 12, 2024 11:33 pm
Great! Good work guys. Its nice to see a company listen to their customers and working on issues still. Have a good rest of the week!
Br
mechcnc
Postby AutomaticInvest_4 » Tue Jan 21, 2025 12:18 pm
Hello,
I think you can modify the macro associated with M3 which is M3.txt
By default M3.txt consists of
exec.DospinCW();
which turns on plasma. Let's say you have the Led number 63 on the screen that is true only when receiving arc OK, and false when no arc OK
By adding the following code after this line in M3.txt:
int waiting = 0;
bool waiting_b = true;
double SafeZ = 60.0;
while (true != AS3.GetLED(63))
    exec.Wait(5);
    waiting += 5;
    if (waiting > 2000)
        waiting_b = false;
        break;
if (false == waiting_b)
    exec.Code("M5");
    exec.Code("G0 Z" + SafeZ);
should be a solution
So if waiting 2000 milliseconds (or other time interval) and there is still no arc OK, then we stop plasma and go to SafeZ
AutomaticInvest_4
Return to CNC Plasma
