Also I am notice if arc or circle consist from small parts (usually if dxf file generated in the CorelDraw) antidive future always activated, because UCCNC constantly accelerate/decelerate on every small part. If I am decrease Threshold value antidive not activated on this parts, but not activated on the corners and end of cut. I think we can not do anything.
It's sad
Well, if the decceleration is because of the setup rules, defined by the acceleration parameter of the axes and the CV parameters then we can't do much about that, because it will be the physical limit of how the path can be followed, how the machine can accelerate and follow the different paths. And the anti dive function is a simple rule, it will always trigger when the feedrate drops below the set threshold level.
Unfortunately the limitation will be always the Physics on Earth, we can't override that. yet
Just a simple example is X=0 and G1 X10, G1 X0, with this code the axis simply changing direction, so it has to deccelerate and accelerate up again and so the anti dive function will trigger when the feedrate drops.
The only way to avoid this situation would be to have an infinate acceleration, and basicly that would be only possible if your motors have zero inertia and your machine axis has a zero mass.
Making the acceleration higher can help, but ofcourse you can't make it infinate high in reality.
