Button (Macro) - Call *.exe
Postby Robertspark » Thu Aug 03, 2017 1:40 pm
Similar principle to the call (open) usermanual PDF.
.... this one just starts a program of your choosing from a UCCNC screenset button press, in this case Sheetcam (obviously won't work for you directly unless you have sheetcam ..... hence change it to the program of your choosing [vectric, autocad, stepper motor tuning software [leadshine protuner from the diagnostics screen] etc...
System.Diagnostics.Process Sheetcam = new System.Diagnostics.Process();
Sheetcam.StartInfo.FileName = @"C:\Program Files (x86)\SheetCam TNG Development\SheetCam TNG Development.exe";
Sheetcam.Start();
M20001.txt
(202 Bytes) Downloaded 1531 times
Re: Button (Macro) - Call *.exe
Postby dezsoe » Thu Aug 03, 2017 2:05 pm
The same technique to use your favorite text editor to edit g-code. Edit screen and change "Edit file" buttonnumber from 126 to 20126. In M20126.txt change the path to your favorite text editor.
// 126 -> 20126 -> external code editor
string sFileName = exec.mainform.filenametoload;
if ((sFileName == "") || (sFileName == Application.StartupPath + "\\Contents\\Empty.txt"))
  AS3.Additemtolistbeginning("No file loaded!", 2);
  return;
System.Diagnostics.Process proc;
proc = System.Diagnostics.Process.Start(@"C:\Program Files (x86)\PSPad editor\PSPad.exe", sFileName);
proc.WaitForExit();
exec.mainform.loadfile();
M20126.txt
(446 Bytes) Downloaded 1561 times
Postby Robertspark » Wed Dec 25, 2019 11:04 pm
help.....
Trying to work out how to get focus / setfocus to a process that is already loaded....
I've got this far.... but I cant seem to get "SetForegroundWindow" to work for me
System.Diagnostics.Process[] localByName = System.Diagnostics.Process.GetProcessesByName("SheetCam TNG Development");
if (localByName.Length > 0){
//System.Diagnostics.Process Sheetcam = new System.Diagnostics.Process();
//localByName.Start();
return;
else {
Sheetcam.Start();
I've tried various things after the "if (localByName.Length > 0){" and just cannot seem to be able to give focus to an already loaded process, instead of loading another occurance
Any guidance would be greatly appreciated, thanks,
Postby Robertspark » Thu Dec 26, 2019 11:55 am
well, I got this far:
System.Runtime.InteropServices.DllImportAttribute import = new System.Runtime.InteropServices.DllImportAttribute("USER32.DLL");
but I cannot get this to run error free.... (yet)
public static extern bool SetForegroundWindow(IntPtr hWnd);
trying to use this way of doing it:
https://shatter-box.com/knowledgebase/b ... th-csharp/
Return to UCCNC TOOL BOX
