Travel the Extents of a Gcode program
Re: Travel the Extents of a Gcode program
Postby Robertspark » Sat Oct 29, 2016 8:40 am
Similar macro to TP's below (copied from cnczone where I posted it a while ago on there).
May be of use having it in one location and along a similar thread.
TP's uses inches ... this one uses whatever units you have set, but you do need to set the feedrate (once set should be good for all future macro runs).... save it as a greater than 20000 macro number and run it from an onscreen button you want to add.
M1020.txt
(2 KiB) Downloaded 1063 times
Return to UCCNC TOOL BOX
