With regards to the default scope plugin, would it be possible to obtain the sourcecode for this plugin?
Or allow for it to be modified to be able to display other things such as monitor pin status changes, selected axis velocity, spindle speed and any other inputs or outputs?
The logging speed also appears quite slow, hence I was wondering if this could be adjusted via a setting or access to the sourcecode?
Seems like quite a handy tool, just requires a bit more development
