Issues with Movement...
Postby SpillSesh » Tue Feb 27, 2024 5:58 am
Hi Guys,
I've trying to work on this for over a week now... Absolutely stumped.
I've plugin that controls a drill moving from Z0 to Z-(a variable). When I click the pause button I want it to retract 1mm (which is in the positive direction). I've managed this in two ways, neither of which are acceptable. Need help please.
The below works but requires me to click OK on a popup box. I don't like this solution because it's an extra action from the operator, and if the operator is slow or forgets, then the drill tip will rub during spindle deceleration.
UC.StopWithDeccel(); //Stops the G - code execution
double Z_Pos_Desired = UC.GetZpos() + 1;
MessageBox.Show(new Form { TopMost = true }, "Drill will be retracted by 1mm to prevent rubbing", "Drilling Operation Paused", MessageBoxButtons.OK, MessageBoxIcon.Exclamation);
UC.Code("G0 Z" + Z_Pos_Desired);
For an unknown reason, if I remove the MessageBox then it always returns to Z0 (not ideal). This happens regardless of whether I call the command from the plugin or a Macro.
I have also tried the button route:
UC.Callbutton(166); // Sets the jog distance when stepping mode to 1.00 Units
UC.Callbutton(162); // Sets the jog mode to stepping.
UC.Callbutton(151); // Jogs the Z axis to positive direction 1mm (away from cut face, stops rubbing)
This works, but only once per UCCNC startup. If I press this plugin PAUSE button again and haven't restarted UCCNC, then it does nothing.
Can anyone explain what is going on? Got any ideas to achieve this without the MessageBox.Show?
Regards,
Jesse.
SpillSesh
Re: Issues with Movement...
Postby dezsoe » Tue Feb 27, 2024 3:47 pm
You try to start a new movement while the Z is decelerating. Wait for the stop to execute:
                while (UC.IsMoving())
                    Thread.Sleep(10);
Postby SpillSesh » Wed Feb 28, 2024 8:47 am
Thanks dezsoe,
I tried this and it still returns to Z0, not Z_Pos_Desired.
Any other ideas?
SpillSesh
Postby dezsoe » Wed Feb 28, 2024 9:07 am
That's interesting, because I tested the code. That is why it is indented: I just copied from my test plugin. What else is in your code and which version of UCCNC did you try?
Postby SpillSesh » Wed Feb 28, 2024 10:43 pm
Version 1.2116
There is a lot of other stuff in my code....
(I pasted it here but deleted it because I found a solution), see post below.
SpillSesh
Postby SpillSesh » Wed Feb 28, 2024 10:59 pm
Yep, something weird is going on.
This stops as required.
This stops then returns to Z0 (when it shouldn't):
UC.Code("G91");
It seems that anything I write in UC.Code returns to Z0, regardless of what it is...
SpillSesh
Postby SpillSesh » Wed Feb 28, 2024 11:07 pm
Found a solution.
                    Thread.Sleep(100);
                UC.Codesync("G91");
                UC.Codesync("G0 Z1");
                UC.Codesync("G90");
Adding UC.StopWithDeccel() after movement is complete prevents it returning to Z0. I don't know why it does this, but it works for me now...
SpillSesh
