WHB04B-4 Pendant Plugin
Postby shad » Tue Mar 17, 2020 6:59 am
Hello!
For those who want to test out the WHB04B-4 pendant plugin.
Please let me know if there is a bug's.
WHB04B-4 Pendant.rar
(123.55 KiB) Downloaded 3091 times
-- Andrew
UC400ETH
UC300ETH-5LPT
NEURON Lite THC
http://neuroncnc.com/
shad
Re: WHB04B-4 Pendant Plugin
Postby 86bg » Sat Mar 21, 2020 2:13 pm
I'm excited to try it and will get back to you ASAP
86bg
Postby 86bg » Sat Mar 21, 2020 5:44 pm
So far it works amazing and you just saved me a lot of money. What was your workflow for making it usable? I dug into it a little bit but the amount of time it looked like it was going to require didn't seem worthwhile. You nailed it.
So many people are going to come out of the woodwork thanking you because like me they probably bought it without realizing that this exact model didn't have a working plug in already.
Do you intend on releasing the information you acquired while reverse engineering this undocumented pendant?
86bg
Postby 86bg » Sat Mar 21, 2020 6:18 pm
Are the Alternate "FN" buttons adjustable?
86bg
Postby Vance » Sat Mar 21, 2020 10:42 pm
86bg wrote:Are the Alternate "FN" buttons adjustable?
Tell us what is working.
Thanks.
________________________________________________________________
Vance
CNC Router Parts 48/96, 23,
ST-M5045 drivers
/ETH-5LPT/UCSB
Carveco Maker
Vance
Postby shad » Sun Mar 22, 2020 9:05 am
Yes, alternate buttons are usable too.
Information was gathered from the various sources (Linux CNC machinekit project) and of course had to sniffer the USB port.
-- Andrew
UC400ETH
UC300ETH-5LPT
NEURON Lite THC
shad
Postby 86bg » Sun Mar 22, 2020 4:28 pm
Are they adjustable like the Macro buttons?
I ask because I know that M-Home homes the machine but w-home button doesn't make any sense to me.
86bg
Postby Vance » Sun Mar 22, 2020 8:34 pm
86bg wrote:Are they adjustable like the Macro buttons?
Check page 10.
https://www.edingcnc.com/upload/files/xhc-pendant-manual.pdf
Vance
ST-M5045 drivers
/ETH-5LPT/UCSB
Carveco Maker
Vance
Postby formantjim » Thu Mar 26, 2020 3:20 pm
I just came across this post as I have just added a laser to my CNC machine. I had been using Mach 3 with ESS and kept having so many errors with the ESS that I switched to UC 300ETH and it has been fantastic for milling. But now with the laser the Mach 3 post processors for Inventor CAM that I use are poor to say the least so I ran into the issue that using Mach 3 with the UC 300ETH is not a good combination. So I decided to give UCCNC a try but found that it did not have support for either my Huanyang VFD with modbus or the wireless pendant WHB04B-4 so left it well alone till your posting of the latest plugin. I too did not want to go and buy a new one so with great hopes I rushed to my machine loaded up UCCNC and installed your plugin but alas it does connect and show the coordinates correctly on the Pendant and on the DRO's of UCCNC but no movement or any further commands are enabled or controlled. The plugin once set to both call and enable just causes the Pendant window to open it says its found it but then hangs and I have to reboot UCCNC to get rid of the pop up window.
I'm running Windows 10 not connected to the internet or anything totally stand alone also UCCNC version 1.2111 the previous Mach 3 UC300ETH setup has been running flawlessly for 2 years. This would be my ultimate dream to have this working because I have also since found another potential plugin for the VFD so I could make the switch to UCCNC permanent.
Any guidelines or help you can give me to get this running would be much appreciated.
formantjim
Postby formantjim » Thu Mar 26, 2020 4:56 pm
OK an update since I've now spent some more time testing it out.
The pendant will work all axis with only the step command no continuous motion, spindle start stop works perfectly, reset works, Fn Feed + and Feed - work correctly.
So we are very close to having it fully functional exciting times!
formantjim
