XHC-HB04 pendant + "sensor was active"
Postby sebmay » Wed Nov 14, 2018 3:39 pm
Hello,
I know many users talked about that problem, but it was a long time ago.
I made some pure tests.
With the plugin for the XHC-HB04 enabled, i get many spurious "the sensor was active" error when calling G31. More than twice per dozen of G31. But generally, after the first occurrence, all G31 fails until uccnc is exited.
With that plugin DISABLED, all G31 works. Always.
I manage to run uccnc WITHOUT that plugin for large probing session. That could be affordable. This a preparation session before actually carving.
BUT ! then cannot use G31 in order to get the tool height adjusted while carving.
Can you investigate this, please ?
Sebastien
sebmay
