I read this in the Feature Request section and thought it was a good idea and I could find use, had some play time today and was simple to write. This plugin will save the last 10 Gcode files loaded in UCCNC removing the oldest when replacing with new. You can click on file to quickly load.
1. Put dll file in your UCCNC Plugin folder and check Call Startup and Enable.
2.Create a button in screen edit and give it button# 6222, or create a hotkey and use 6222 for function code, or put macro I included in zip file
and add to the Multi Macro button I previously uploaded.
