Autoleveler Plugin.
Re: Autoleveler Plugin.
Postby VSievert » Mon Jan 27, 2020 1:05 pm
Cahit,
I have been using Autoleveller with UCCNC the past few months and absolutely love it. I too am using a setup that is imperial and am looking forward to your next release.
Thanks for all the effort.
Vince
VSievert
Postby cahit » Mon Jan 27, 2020 7:53 pm
Hi VSievert,
i have a not functional version with very flexible settings ready. please take a look for it and let me know is this is ok for you and others.
any sugestions are welcome.
note: this is version 3
regards...
AutolevelerCA.rar
test version
(389.28 KiB) Downloaded 1182 times
cahit
Postby VSievert » Fri Jan 31, 2020 12:32 am
Thanks Cahit,
I will give it a try and let you know how it works,
Thanks again,
Vince
VSievert
Postby cahit » Mon Feb 03, 2020 2:30 pm
Hello people,
here an update of development new autoleveler.
cheers
AutolevelerCA v3.031 development version.rar
(754.44 KiB) Downloaded 1375 times
cahit
Postby submustang » Sat Feb 15, 2020 1:54 am
Cahit,
I finally got a chance to checkout test version 3, but can't seem to get it to load. I am running UCCNC V1.2049, is the test version compatible with the version I am running?
Vince
submustang
Postby Demusman » Sun Feb 16, 2020 12:10 pm
Can anyone tell me the point of an this autolevel??
I get it for 3d printers but not for mills.
You get the work piece to be level with the Z axis, SO???, the bit will still be 'unlevel'.
What good is that?
Demusman
Postby dezsoe » Sun Feb 16, 2020 12:14 pm
Most people use it for PCB milling. See: https://github.com/Daedelus1982/AutoLeveller
Postby submustang » Sun Feb 16, 2020 3:32 pm
Cahit,
I updated to UCCNC V1.2111 and loaded the test version 3 you recently made available. After installing autoleveler test version 3 and enabling the plugin I am getting the following error message
"Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately.
Exception of type 'System.OutOfMemoryException' was thrown"
If I choose to continue I just get a blank screen.
Vince
submustang
Postby submustang » Sun Feb 16, 2020 3:36 pm
Demusman wrote:Can anyone tell me the point of an this autolevel??
What good is that?
I use auto leveler to map surfaces that are not level, then apply a tool path and carve. There are many instances where surfacing the material is not desired.
submustang
Postby Demusman » Tue Feb 18, 2020 11:28 am
What good is that?
This is my point, complete waste of time. If you're talking abaout 3d carving, There's absolutely no need to surface the material as the carve will be below the top anyway.
dezsoe wrote:Most people use it for PCB milling. See: https://github.com/Daedelus1982/AutoLeveller
That's a perfect use of this. It's been a while since I've dona any PCB's but I will definitely try it next time I do.
Thanks!
Demusman
